Hello, I'm Dominik and I come from Poland  My German isn't good so I hope that You understand me. So, a few days ago I bought Audi 80 B4 Limo with 2.0 ADR and Automatic gearbox CFW. I rode arround market (the car was Abmeldung?!) - think that's all OK. Yesterday I bought 5-days yellow boards/Blach?! and go to my Audi (it stayed in Ruckersdorf). It seemed to me that car hasn't power but maybe engine is cold... When I was in Schwaig the engine had 90 degrees and Audi still no riding normal... According to ride I noticed that gearbox not switch gear, is working only in 3th gear (in D). (R)everse work normal, (P)arking and (N)eutral too. When want to start ride and I turn on (1) I have 1st gear, but I would like to start from (2) or (3) I have to only 2nd od 3th gear, without (for example in (3)) first and second gear... In Tacho the gears are change normal, in gearbox (3) = in Tacho is (3) etc. So, I want to buy the VAG-Com or other, for example this: http://www.ebay.de/itm/2x2-Int…%A4te&hash=item2eb8b54013 and read the errors. Where in Nurnberg I can buy it? Can You help me?
 My German isn't good so I hope that You understand me. So, a few days ago I bought Audi 80 B4 Limo with 2.0 ADR and Automatic gearbox CFW. I rode arround market (the car was Abmeldung?!) - think that's all OK. Yesterday I bought 5-days yellow boards/Blach?! and go to my Audi (it stayed in Ruckersdorf). It seemed to me that car hasn't power but maybe engine is cold... When I was in Schwaig the engine had 90 degrees and Audi still no riding normal... According to ride I noticed that gearbox not switch gear, is working only in 3th gear (in D). (R)everse work normal, (P)arking and (N)eutral too. When want to start ride and I turn on (1) I have 1st gear, but I would like to start from (2) or (3) I have to only 2nd od 3th gear, without (for example in (3)) first and second gear... In Tacho the gears are change normal, in gearbox (3) = in Tacho is (3) etc. So, I want to buy the VAG-Com or other, for example this: http://www.ebay.de/itm/2x2-Int…%A4te&hash=item2eb8b54013 and read the errors. Where in Nurnberg I can buy it? Can You help me?  Greetings
 Greetings
VAG Kable in Nurnberg...
			You need another cable to connect to your laptop via USB just like this one right here: click Furthermore you will need the proper software in order to check the ECU for possible errors which would be VCDS Lite or VAGCOM .... However I have no idea where you can buy such a cable in Nürnberg. You could try to find a Conrad store somewhere near by and have them order you the right cable and adapter. It usually doesn't take long and you can pick it up....just talk to them and describe your problem. Hope I could help you out at least a little bit.
			Try this Conrad store in Nürnberg Fürther Straße 212
 90429 NürnbergOpening Times Mo.-Fr. 9.30-20.00 h
 Sa. 9.30-18.00 h
			Of course, I have a ABK 2.0E  ZitatAlles anzeigen ZitatAlles anzeigenTry this Conrad store in Nürnberg Fürther Straße 212
 Sa. 9.30-18.00 hOk, I dress up and go to this shop, thank You very much
			I think the conrad store can´t help you... You need the right connecting-cable for USB-OBD (OBD with 2 connections). I think you can get this cable only in the internet...
			Is it even possible for you to buy a cable online my polish friend?? xD Or are you only in Nürnberg for a short amount of time and you have no adress?
			I have only 3 days (yellow boards), post - too long time...  You're right, Conrad's shop hasn't suitable cable. I'll have to take my Audi on the truck trailer - here is one way. So, thanks for all, Friends You're right, Conrad's shop hasn't suitable cable. I'll have to take my Audi on the truck trailer - here is one way. So, thanks for all, Friends
	 sorry..
 sorry..
