Beiträge von AUDI 80 Aleksandr
    Here are told that engine shakes at idle, this situation may occur in the absence of combustion of the fuel mixture in full, in one of the cylinders, then there is the combustion of different fuels in each of the working cylinders. The reasons for such a work cylinder, maybe three - it is the absence of inflammation, lack of compression and poor quality fuel smesi.Dlya order to determine the specific cause, you need to unscrew the tip of the spark plug. Minimizing the number of idle speed, you can determine the condition of the cylinder: a working or non working. But such a check, how to plant, resulting in failure of the switch, slider, or a possible breakdown ignition distributer cap. To reduce the negative impact of non-standard test for the engine, you want to remove the tip to quickly put on any bolt, with a suitable sized diameters, to reappear flicks spark. Follow basic safety during this test: the engine, always make sure the wilderness, and then removed the tip. Run the engine only after the finalization of the tip.
    english:The car works, in a second starts turns to fall - the car starts to shiver! Then it is sometimes switched off!
    deutsch: Der Wagen arbeitet, durch die Sekunde beginnt die Wendungen, - der Wagen zu fallen beginnt, sich zu schütteln! Wonach manchmal ausgeschaltet wird!
